Home > Puma (Tdci) > Transfer case diff lock lever bushings?
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Would any know the part number for the 2 plastic square "bushings" that are in transferbox
diff lock actuator lever? These inside the red circle.
Strange that there is parts without any part numbers.
 Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #448663 24th Aug 2015 11:34am
Dan is the man for this one of Duckworth parts LR.
http://www.defender2.net/forum/member-duckworthparts.html
Post #448666 24th Aug 2015 11:59am
Td5
OK, sent an inquiry to Duckworth parts.
See no reason why I couldn't purchase all my parts from them
as I usually by LR or OEM parts. There is so much crap available
and the pricing is not so much less. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #448677 24th Aug 2015 12:49pm
I'm sure Dan will be back to you shortly.
Indeed, I have the same philosophy too. Thumbs Up
Post #448706 24th Aug 2015 3:16pm
Parts without numbers are generally only available as part of a larger assembly. Hopefully on this occasion that's not the case and it is simply a mistake.
Post #448761 24th Aug 2015 5:58pm
Td5
Dan replied that these parts are not available separately.
Very strange philosophy from LR. I have to see if these could
be substituted, only one is for some reason a bit broken.
This are plastic bushings. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #448766 24th Aug 2015 6:09pm
If that is the case possibly try breakers on an accident damaged Landy.
Then the parts may be obsolete for purpose but useful to you.
Thornton I've used before.
Post #448774 24th Aug 2015 6:47pm
Td5
These bushings are part of the whole gear lever assembly, P/N TSC500020.
Price w/tax about 100GBP. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #449644 27th Aug 2015 10:51am
Martin
Site Admin
Could you have some made by an engineering company (on a lathe)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #449650 27th Aug 2015 11:09am
Td5
The bushing is outside square and inside round, it's the white part on the left.
Somebody been here before me, I found markings on parts and transmission
bolts was not even tight. Probably clutch has been changed.
There was almost 3l of oil in transmission?
I'll have to look closer to this, wouldn't like to purchase a 100GBP + shipping part for a bushing. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #449658 27th Aug 2015 11:50am
