![]() | Home > Puma (Tdci) > Transfer case diff lock lever bushings? |
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 ![]() ![]() ![]() |
Would any know the part number for the 2 plastic square "bushings" that are in transferbox
diff lock actuator lever? These inside the red circle. Strange that there is parts without any part numbers. ![]() Click image to enlarge Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
Dan is the man for this one of Duckworth parts LR.
http://www.defender2.net/forum/member-duckworthparts.html |
OK, sent an inquiry to Duckworth parts.
See no reason why I couldn't purchase all my parts from them as I usually by LR or OEM parts. There is so much crap available and the pricing is not so much less. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
I'm sure Dan will be back to you shortly.
Indeed, I have the same philosophy too. ![]() |
Dan replied that these parts are not available separately.
Very strange philosophy from LR. I have to see if these could be substituted, only one is for some reason a bit broken. This are plastic bushings. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
If that is the case possibly try breakers on an accident damaged Landy.
Then the parts may be obsolete for purpose but useful to you. Thornton I've used before. |
These bushings are part of the whole gear lever assembly, P/N TSC500020.
Price w/tax about 100GBP. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6714 ![]() ![]() ![]() |
Could you have some made by an engineering company (on a lathe)?
The bushing is outside square and inside round, it's the white part on the left.
Somebody been here before me, I found markings on parts and transmission bolts was not even tight. Probably clutch has been changed. There was almost 3l of oil in transmission? ![]() I'll have to look closer to this, wouldn't like to purchase a 100GBP + shipping part for a bushing. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
