Home > Puma (Tdci) > Dci, not tdci anymore.
landy andy
I will let the picture tell the story.
Post #446380 15th Aug 2015 9:38pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Ouch Shocked
Post #446385 15th Aug 2015 9:45pm
dgardel
Italy
Nakatanenga gasket? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #446386 15th Aug 2015 9:50pm
landy andy
Yep was running a Nak gasket. Why the question? Any thoughts?
Andy
Post #446395 15th Aug 2015 10:33pm
Eduardo
Upps!
Great failure Sad Eduardo
Post #446396 15th Aug 2015 10:36pm
YOLO110
Australia
Andy
Ouch Shocked
WHY would a gasket cause that failure? Are they a variable thickness?? YOLO... You Only Live Once...
Post #446404 15th Aug 2015 11:18pm
dgardel
Italy
Andy
no, but just for understand.
Is your var tuned? Tuner?
It's strange indeed the Nakata gasket is wider and softer.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #446439 16th Aug 2015 9:20am
K9F
I am only speculating but would have thought either the unit had been subject to impact damage, it had a flaw in the material or it had been overtorqued, maybe one or more of the preceding to cause such catastrophic failure perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446441 16th Aug 2015 9:26am
landy andy
Yes was Nak gasket. It's tuned by Alive. The turbo has warped the flange before. First time I just fitted Nak gasket, then second time I refaced the turbo and manifold faces, and fitted Nak gasket. It then failed again so refaced turbo again, and removed cat, fitted free flow exhaust, and Nak gasket thinking this would help.
I can't believe that the turbo flange is weaker than M8 studs, very disappointing.
Andy
Post #446444 16th Aug 2015 9:31am
landy andy
It was on tight, well as tight as you can get M8 nuts with a ring spanner.
Post #446445 16th Aug 2015 9:33am
grafty99
Would that not point towards excessive EGT? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #446451 16th Aug 2015 9:59am
I am of this school of thinking too.
Post #446466 16th Aug 2015 11:28am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
That really is odd. I'd guess the combination of a thicker than usual gasket some overtorque of the bolts and lots of extreme thermal cycles.
Not a good sight.
Jonno
Post #446606 16th Aug 2015 10:01pm
landy andy
All fixed now, so will see how things go.
Post #446616 16th Aug 2015 10:27pm
What did you manage to do in the end?
Post #446643 16th Aug 2015 11:24pm
