![]() | Home > Puma (Tdci) > Dci, not tdci anymore. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
I will let the picture tell the story.
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Ouch
Nakatanenga gasket? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Yep was running a Nak gasket. Why the question? Any thoughts?
Andy |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Upps!
Great failure ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Ouch ![]() WHY would a gasket cause that failure? Are they a variable thickness?? YOLO... You Only Live Once... |
no, but just for understand. Is your var tuned? Tuner? It's strange indeed the Nakata gasket is wider and softer.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I am only speculating but would have thought either the unit had been subject to impact damage, it had a flaw in the material or it had been overtorqued, maybe one or more of the preceding to cause such catastrophic failure perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
It was on tight, well as tight as you can get M8 nuts with a ring spanner.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Would that not point towards excessive EGT? 2002 90 Td5 Station Wagon
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20922 ![]() ![]() |
I am of this school of thinking too. |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
That really is odd. I'd guess the combination of a thicker than usual gasket some overtorque of the bolts and lots of extreme thermal cycles.
Not a good sight. Jonno |
All fixed now, so will see how things go.
What did you manage to do in the end?
