Home > Maintenance & Modifications > Spring orientation
excossack
Spring orientation
Maybe a daft question but...Do suspension springs have a top and a bottom? Or does it not matter which way up they fit? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #442360 2nd Aug 2015 8:38am
munch90
don't it make any difference
but if you have a dual rate spring where some coils one end are closer together then they tend to be fitted with closer coils at the top , but this doesn't matter , but better for looks if they all the same
on some cars you have a top and bottom , but that's only as they have different coil sizes and different fitting top and bottom
Post #442363 2nd Aug 2015 8:45am
excossack
Thanks M90. That helps. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442368 2nd Aug 2015 9:04am
Dave-H
Just to endorse the correct info from munch [top bloke] ...... Cool
The reason tighter coils go top rather than bottom is to stop the spring centres filling up with mud/stones/debris .... Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #442411 2nd Aug 2015 2:18pm
excossack
Springs are in and shocks replaced! Cheers chaps. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442474 2nd Aug 2015 6:22pm
Much of a job?
Post #442494 2nd Aug 2015 7:07pm
excossack
5.5 hrs inc 1hr for bacon butties and 40 mins pause while rain appeared and some fun and games with a sheared nut on the spring plate 1999 Defender TD5 110
Regards
John M0VAZ
Post #442496 2nd Aug 2015 7:10pm
Not surprised with those due to their location.
I like to have new spares just in case if I need them.
Thumbs Up
Post #442499 2nd Aug 2015 7:12pm
excossack
I had new ones but the bolt sheared so drilled out and replaced with nut and bolt rather than a bolt with a captive. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442500 2nd Aug 2015 7:16pm
