![]() | Home > Maintenance & Modifications > Spring orientation |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
don't it make any difference
but if you have a dual rate spring where some coils one end are closer together then they tend to be fitted with closer coils at the top , but this doesn't matter , but better for looks if they all the same on some cars you have a top and bottom , but that's only as they have different coil sizes and different fitting top and bottom |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041
Thanks M90. That helps. 1999 Defender TD5 110
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Just to endorse the correct info from munch [top bloke] ......
The reason tighter coils go top rather than bottom is to stop the spring centres filling up with mud/stones/debris .... |
Springs are in and shocks replaced! Cheers chaps. 1999 Defender TD5 110
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Much of a job?
5.5 hrs inc 1hr for bacon butties and 40 mins pause while rain appeared and some fun and games with a sheared nut on the spring plate 1999 Defender TD5 110
Not surprised with those due to their location.
I like to have new spares just in case if I need them. |
I had new ones but the bolt sheared so drilled out and replaced with nut and bolt rather than a bolt with a captive. 1999 Defender TD5 110
