![]() | Home > Puma (Tdci) > Puma EGR fault |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Hi and welcome Old Yella.....All information is gladly received
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
That's nice to know
![]() I assume your warranty is up. 130 crew cab 98 V8 Disco |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
Hi Old Yella
how much was the part ... just out of interest..? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
thanks for the info yella
![]() 1968 1/32 scale Britains 109 Pick up. |
Old Yella Member Since: 23 Aug 2010 Location: Wales Posts: 2 ![]() ![]() |
![]() in Chester UK. I could have got the parts off EBay for a little less. I wanted to get the fault sorted quickly, the main dealer had it on the shelf, 1 hours round trip for me to the main dealer. Bwlchgwyn |
Old Yella... was that James Edwards...if so they are pretty good to deal with............use them all the time as my lanny is always needing something
Old Yella,
Welcome to the site and interesting post from a fellow 'EGR Valve problem sufferer.' I would also do as you have done buy a new one and then investigate the old. I could not afford the 'downtime' not to buy a new and rip the old one apart trying to fix it. Historically I knew my EGR Valve was on the way out and it was my intention of removing it and using brake cleaner to thoroughly clean it. I never found the time to do that before it gave up the ghost and I had to call LR Assist in the end and have a replacement fitted under warranty! ![]() Treat every day as if it is your last....one day you will be right!! |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
My noisy EGR valve was "fixed" by being lubricated by all the oil pi**ing from the brake vacuum pump!
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 ![]() ![]() ![]() |
You think yours was noisy ! I,m traveling with my landy at the min and every time I turn the engine off in a public place you should see the looks I get!! It sounds like a choking cat! And getting worse by the day. I,ll will be of to the stealer when I get back . I have been told that new egr valves are modified in some way as to stop these probs. ![]() ex 1988 defender 90 ,td ex 1970 series III |
That's exactly how mine died - at least the dealer could hear it loud and clear.
The new one looks different on the outside to the old one but can't put my finger on exactly what - I think it has an additional hole going into the body of the EGR valve - will try and take a snap of the new valve tonight |
A pic or two could be useful thanks I,d like to know what they have changed for blanking purposes. ![]() ![]() ex 1988 defender 90 ,td ex 1970 series III |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
If driving in too low a gear and at high revs is good for the EGR valve, mine will last for ever. The wife drives mine.
![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
This is a picture of the new EGR valve - a bit jumbled because of all the pipes nearby.
It shows a hole about 19mm diameter from the top that I am not sure was there on the old one. Maybe someone can snap a pic of the older type (2007 model) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
