Home > Puma (Tdci) > Puma EGR fault
Old Yella
Puma EGR fault
Very Happy Hi all just registered so may not get this first attempt correct?
Got a MIL light on my 2007 Puma pickup, plugged in the Hawk, fault EGR,
replaced this week end, fault sorted. Dismantled the old EGR and found the issue
to be electrical connection to EGR drive motor badly pited and high resistence.
Cleaned connections and re-established working EGR, could have saved myself
some money. I hope this may help any one else with a silmilar fault. Bwlchgwyn
Post #38907 23rd Aug 2010 4:13pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Hi and welcome Old Yella.....All information is gladly received Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #38911 23rd Aug 2010 4:55pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
That's nice to know Thumbs Up
I assume your warranty is up. 130 crew cab
98 V8 Disco
Post #38912 23rd Aug 2010 5:28pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Old Yella
how much was the part ... just out of interest..? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #38916 23rd Aug 2010 6:12pm
CapeLandy
South Africa
Post #38937 24th Aug 2010 6:56am
Grockle
thanks for the info yella Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #38943 24th Aug 2010 8:27am
Old Yella
Smile Hi all, yes my warranty is up, the cost of the EGR and gaskets was £101 from a main Landrover dealer
in Chester UK. I could have got the parts off EBay for a little less. I wanted to get the fault sorted quickly,
the main dealer had it on the shelf, 1 hours round trip for me to the main dealer. Bwlchgwyn
Post #38954 24th Aug 2010 11:28am
fekete
Old Yella... was that James Edwards...if so they are pretty good to deal with............use them all the time as my lanny is always needing something Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #38975 24th Aug 2010 5:03pm
K9F
Old Yella,
Welcome to the site and interesting post from a fellow 'EGR Valve problem sufferer.' I would also do as you have done buy a new one and then investigate the old. I could not afford the 'downtime' not to buy a new and rip the old one apart trying to fix it.
Historically I knew my EGR Valve was on the way out and it was my intention of removing it and using brake cleaner to thoroughly clean it. I never found the time to do that before it gave up the ghost and I had to call LR Assist in the end and have a replacement fitted under warranty! Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38996 25th Aug 2010 8:28am
shingwell
My noisy EGR valve was "fixed" by being lubricated by all the oil pi**ing from the brake vacuum pump!
Post #39005 25th Aug 2010 9:46am
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
You think yours was noisy ! I,m traveling with my landy at the min and every time I turn the engine off in a public place you should see the looks I get!! It sounds like a choking cat! And getting worse by the day. I,ll will be of to the stealer when I get back . I have been told that new egr valves are modified in some way as to stop these probs. Thumbs Up 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #39017 25th Aug 2010 12:02pm
CapeLandy
South Africa
That's exactly how mine died - at least the dealer could hear it loud and clear.
The new one looks different on the outside to the old one but can't put my finger on exactly what - I think it has an additional hole going into the body of the EGR valve - will try and take a snap of the new valve tonight
Post #39018 25th Aug 2010 12:24pm
Robofarmer
A pic or two could be useful thanks I,d like to know what they have changed for blanking purposes. Thumbs Up Thumbs Up 2008 110 County utility
ex 1970 series III
Post #39020 25th Aug 2010 12:40pm
spudfan
Ireland
If driving in too low a gear and at high revs is good for the EGR valve, mine will last for ever. The wife drives mine. Very Happy Very Happy 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #39040 25th Aug 2010 5:28pm
CapeLandy
South Africa
This is a picture of the new EGR valve - a bit jumbled because of all the pipes nearby.
It shows a hole about 19mm diameter from the top that I am not sure was there on the old one. Maybe someone can snap a pic of the older type (2007 model)
Post #39188 27th Aug 2010 7:23am
