Home > Wheels & Tyres > Goodyear Wrangler MT
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Anyone had an issue with balancing these things? had a new set of these fitted to new sawtooths delivered. Didnt notice the vibrations at first as live in the new forest and speed limit is 40. At around 55 + it vibrated really badly, so took it my local tyre depot, where he tested each wheel. Every wheel needed re-balancing. Refitted and a little better. But at 70 its terrible, 80 is slightly better.
is the dot on the tyre meant to be inline with the valve?
Supplier said "this is normal"
Post #441456 29th Jul 2015 5:51pm
Cuthbert
I have these tyres fitted to HD Steel Rims and had to go to a tyre shop that specialises in Ford Transits in order to get a decent job done.
By using a fancy computerised machine for commercial vehicles, the technician did a neat job, although two of the rims ended up with a fair amount of weights to get a decent result. I now have zero issues at any speed and I'm delighted with the tyres.
I understand that the cone for the balancing machine is the same one as for a Ford Transit and the average tyre shop doing cars won't invest in the correct tool.
Post #441560 29th Jul 2015 11:16pm
nicks
Thanks for the above answer. I'll try this, otherwise they will be going back to the supplier as unfit for purpose. At a steady 80 it's not to bad, until you have to turn slightly then vibrations start again.
Post #442408 2nd Aug 2015 1:53pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
I have these fitted on 16 inch sawtooths I don't have any vibration as such but they do appear to make a drumming/humming warble at 50 plus?? Do yours make noise as well?
I was trying to figure out what it was.
Post #442655 3rd Aug 2015 10:48am
nicks
yes,mine have the same type of noise.
not happy at the amount of vibration im getting though.
Post #446075 14th Aug 2015 1:53pm
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
Had mine fitted a couple of months ago.
They are on 30mm spacers and no wobbling or noise at all.
Mind you they were fitted by AJS tyres!
Andy Defender Td5 XS90
Post #446103 14th Aug 2015 3:32pm
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Are your sawtooths original or aftermarket?
If aftermarket, it may be the rims. I bought a set recently with BFG at's and they had a wobble at 55 ish, three different tyre companies balanced them saying the machine said they were ok, but clearly they weren't. They were sent back to the supplier and a full refund given..
I run the good years on wolf rims at moment, factory supply and no issues what so ever.
Pete
Post #446105 14th Aug 2015 3:44pm
stanley
I have theses on dual finish alloys , no problems at all.
Post #446133 14th Aug 2015 4:51pm
Wheel
Strangely i've Just swapped my Wranglers on Boosts to BFG's on 18" Overfinch Apollo's today but no probs at all or on my prev 64 plate (rejected due to poor LR build quality) and performed excellently in the 4500 miles i did in it, even up to 85 - 90mph altho i haven't been so fast in my new 15 plate 90.
I'd thoroughly recommend them and had them fitted as an extra when i ordered my original 90 just in case i should ever want to venture off road !!!!
Wheels were a good shout.
Have you sorted this now and what was it ???
Post #448393 22nd Aug 2015 11:44pm
windymiller
I use several sets of MTR on 2 wheel types one being Genuine Sawtooth alloys and no problem what so ever at any speed
Post #448712 24th Aug 2015 3:45pm
Re: Goodyear Wrangler MT
what colour is the dot?
Post #448719 24th Aug 2015 4:10pm
RRUK
That will just be standard mud terrain pattern tyre drone. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #448721 24th Aug 2015 4:15pm
Snowy90
More Soundproofing then and turn the stereo up!
Post #448730 24th Aug 2015 4:35pm
