![]() | Home > Wheels & Tyres > Goodyear Wrangler MT |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
I have these tyres fitted to HD Steel Rims and had to go to a tyre shop that specialises in Ford Transits in order to get a decent job done.
By using a fancy computerised machine for commercial vehicles, the technician did a neat job, although two of the rims ended up with a fair amount of weights to get a decent result. I now have zero issues at any speed and I'm delighted with the tyres. I understand that the cone for the balancing machine is the same one as for a Ford Transit and the average tyre shop doing cars won't invest in the correct tool. |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
Thanks for the above answer. I'll try this, otherwise they will be going back to the supplier as unfit for purpose. At a steady 80 it's not to bad, until you have to turn slightly then vibrations start again.
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
I have these fitted on 16 inch sawtooths I don't have any vibration as such but they do appear to make a drumming/humming warble at 50 plus?? Do yours make noise as well?
I was trying to figure out what it was. |
yes,mine have the same type of noise.
not happy at the amount of vibration im getting though. |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 ![]() ![]() ![]() |
Had mine fitted a couple of months ago.
They are on 30mm spacers and no wobbling or noise at all. Mind you they were fitted by AJS tyres! Andy Defender Td5 XS90 |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 312 ![]() ![]() |
Are your sawtooths original or aftermarket?
If aftermarket, it may be the rims. I bought a set recently with BFG at's and they had a wobble at 55 ish, three different tyre companies balanced them saying the machine said they were ok, but clearly they weren't. They were sent back to the supplier and a full refund given.. I run the good years on wolf rims at moment, factory supply and no issues what so ever. Pete |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
I have theses on dual finish alloys , no problems at all.
Wheel Member Since: 29 May 2014 Location: Essex Posts: 233 ![]() ![]() |
Strangely i've Just swapped my Wranglers on Boosts to BFG's on 18" Overfinch Apollo's today but no probs at all or on my prev 64 plate (rejected due to poor LR build quality) and performed excellently in the 4500 miles i did in it, even up to 85 - 90mph altho i haven't been so fast in my new 15 plate 90.
I'd thoroughly recommend them and had them fitted as an extra when i ordered my original 90 just in case i should ever want to venture off road !!!! Wheels were a good shout. Have you sorted this now and what was it ??? |
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
I use several sets of MTR on 2 wheel types one being Genuine Sawtooth alloys and no problem what so ever at any speed
what colour is the dot? |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
That will just be standard mud terrain pattern tyre drone. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
More Soundproofing then and turn the stereo up!
