![]() | Home > Td5 > ABS/TC lights on following CV swap |
They should be seated all the way home to make the gap as small as possible. Had issues myself with this.
![]() http://www.defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 803 ![]() ![]() ![]() |
Thanks for that,
Essentially your saying they want to be all the way home?- ie the 'collar' on the top should sit flush with the top of the hub carrier rather than the 1-2mm gap I can currently see We gave them a fair tap with a hammer and a suitable implement to knock them down- still seems to be a small gap- I will try and get a photo of it later, bit worried about causing damage if I tap them harder! Many thanks again Chris |
just in case , sure the cv you fitted had the ring on it
The sensor needs to be in all the way into the hub. Did you also replace the bush?
There can be a couple of other causes for the warning lights after replacing CV joints: Replaced with non ABS CV joints, (no notches cut into CV face) Excessive end float Issue with old to new harness connection ![]() |
CVs were definitely the ABS ones
![]() We didn't replace the bushes- we did replace the seals though- are the bushes likely to be the root of the issue? Thanks Chris |
ive seen it done ![]() |
Thanks for the replies,
Im going to have them out again at some point this week and try and re-seat them Chris |
