Home > Td5 > ABS/TC lights on following CV swap
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Hi All, could do with a bit of advice please!?
Myself and 'Rallysteve' did a swap of the CV joints on my 110 yesterday and I now have the ABS and TC lights on permanently having taken them out and replaced them during the process. We also fitted new pads at the same time and had to push the pistons back a fair bit......
2 questions
1 how deep should they be seated in the top of the hub carrier- mine protrude about 1-2mm between the top of the casting and the bottom of the flanged section of the sensor.
2 Does anyone with a a nanocom or hawkeye in South Yorkshire fancy giving it a talking to to see what the problem is?!
Many thanks in advance
Chris
Post #435868 5th Jul 2015 9:48am
K9F
They should be seated all the way home to make the gap as small as possible. Had issues myself with this. Thumbs Up
http://www.defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!!
Post #435869 5th Jul 2015 9:50am
Chris86
Thanks for that,
Essentially your saying they want to be all the way home?- ie the 'collar' on the top should sit flush with the top of the hub carrier rather than the 1-2mm gap I can currently see
We gave them a fair tap with a hammer and a suitable implement to knock them down- still seems to be a small gap- I will try and get a photo of it later, bit worried about causing damage if I tap them harder!
Many thanks again
Chris
Post #435874 5th Jul 2015 10:07am
munch90
just in case , sure the cv you fitted had the ring on it
Post #435875 5th Jul 2015 10:11am
Lorryman100
The sensor needs to be in all the way into the hub. Did you also replace the bush?
There can be a couple of other causes for the warning lights after replacing CV joints:
Replaced with non ABS CV joints, (no notches cut into CV face)
Excessive end float
Issue with old to new harness connection Thumbs Up
Post #435876 5th Jul 2015 10:19am
Chris86
CVs were definitely the ABS ones Laughing
We didn't replace the bushes- we did replace the seals though- are the bushes likely to be the root of the issue?
Thanks
Chris
Post #435880 5th Jul 2015 10:36am
munch90
ive seen it done Laughing
Post #435881 5th Jul 2015 10:59am
Chris86
Thanks for the replies,
Im going to have them out again at some point this week and try and re-seat them
Chris
Post #435937 5th Jul 2015 5:15pm
