![]() | Home > Technical > 90/110 axle differences |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
front and rear what are the differences
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
If you have abs and a 90 they are vented...unless lr treated me
![]() Arent the rear diffs different between a 90 and 110 - the latter being slightly stronger?? Mike |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8476 ![]() ![]() ![]() |
good point, i wasnt aware of that ref ABS. i think the diffs are the same now across the 90/110s. they used to fit the Salisbury to rear 110 which went out with the later td5s replaced by the P38 diff. i know 110 Utility ones are 4 pin - not sure what a 90 one is 2 or 4 pin. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
i thought the 90 could be 2 pin, but im not sure so would stake 1p on it! Mike
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
I believe 90 is 2 pin 110 is 4 pin |
