Home > Technical > 90/110 axle differences
ibexman
front and rear what are the differences
Post #37921 11th Aug 2010 8:10pm
jst
i am assuming you mean differences between the front and rear axle bodies?
rear has a P38 style shorter diff housing 90 & 110 now
ARB mountings - i believe different F to R same 90/110
Shock mounts - f - r different
track rods on rear with A Frame, radius arms and panhard on the front same 90 and 110
outside of the body and avoiding the obvious CVs etc.
110 fronts are vented
4 pot calipers front 2 pot rear. same for 90 and 110s Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37925 11th Aug 2010 9:15pm
mse
If you have abs and a 90 they are vented...unless lr treated me Whistle
Arent the rear diffs different between a 90 and 110 - the latter being slightly stronger?? Mike
Post #37943 12th Aug 2010 7:05am
jst
good point, i wasnt aware of that ref ABS.
i think the diffs are the same now across the 90/110s. they used to fit the Salisbury to rear 110 which went out with the later td5s replaced by the P38 diff. i know 110 Utility ones are 4 pin - not sure what a 90 one is 2 or 4 pin. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37959 12th Aug 2010 10:09am
mse
i thought the 90 could be 2 pin, but im not sure so would stake 1p on it! Mike
Post #37967 12th Aug 2010 10:42am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
I believe 90 is 2 pin 110 is 4 pin
Post #37990 12th Aug 2010 8:11pm
