Home > Td5 > Fan control terminals
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Hello!
Whilst re- plumbing my aerial cables due to a cock up I took the instrument binnacle out.
On the left hand side the heater blower control, there's one terminal at the top and two at the bottom. I'm not sure if they were ever connected or not but o noticed that the one up from bottom ie middle was connected but the wire to the one at the top and the wire to one at bottom weren't connected.
Should they be?
Thanks! It's a standard td5 county with no air con
Post #434355 28th Jun 2015 8:24pm
Martin
Site Admin
Top connection (body of blower switch) - black - ground
Middle connection - green/yellow - speed 1 (slow)
Bottom connection - green/slate - speed 2 (less slow)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #434496 29th Jun 2015 9:28am
Northernremedy
Amazing!!!! Thank you.
I'd better whip it off and check. I took my best guess and it seems to work fine so I assume it must be correct.
Thanks Martin Smile
Post #434501 29th Jun 2015 9:46am
