Home > For Sale & Wanted > [Wanted] LT230 Transfer Box Hi/Lo Range Switch
rallysteve
Some muppet has cut the cables off the one on our 110 and not left enough cable to re-solder them.
Does anyone have a spare working one lying around, they are getting towards £50 new and not willing to spend that much on one!
Post #432823 22nd Jun 2015 2:20pm
There as (as far as I recall) two types. The earlier type has spade connectors and is generally as cheap as chips, the larter type has a tail with an integral connector and these aren't.
I believe that the two are wholly interchangeable mechanically, so if it is the later typre you need you might consider fitting the earlier one and modifying the harness to suit.
Post #432845 22nd Jun 2015 4:49pm
rallysteve
Cheers. Thought that only related to the reverse light switch. They must have only been fitted from TD5 onwards and ours is a 2002 so would think it would be early but has a molded connector on.
Will have another look around. I do have the mating half of the connector so can always cut and solder.
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #432862 22nd Jun 2015 6:34pm
Pretty sure it applies to all. When I tried to rob a switch off my spare Disco2 box to use on the Puma, the Disco was the early type and wasn't sutable. I forget if it was difflock or hi/lo I was after though.
Post #432915 22nd Jun 2015 9:59pm
munch90
Think there on ebay about 35 quid
Post #432916 22nd Jun 2015 10:02pm
