![]() | Home > For Sale & Wanted > [Wanted] LT230 Transfer Box Hi/Lo Range Switch |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242
Some muppet has cut the cables off the one on our 110 and not left enough cable to re-solder them.
Does anyone have a spare working one lying around, they are getting towards £50 new and not willing to spend that much on one! Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
Cheers. Thought that only related to the reverse light switch. They must have only been fitted from TD5 onwards and ours is a 2002 so would think it would be early but has a molded connector on.
Will have another look around. I do have the mating half of the connector so can always cut and solder. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18003
Pretty sure it applies to all. When I tried to rob a switch off my spare Disco2 box to use on the Puma, the Disco was the early type and wasn't sutable. I forget if it was difflock or hi/lo I was after though.
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
Think there on ebay about 35 quid
