- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
BykerPete
| Loose pipe - is it a problem | |
Morning all.
Just having a poke around on my 2.2 Tdci and noticed that the plastic pipe marked on the image in my gallery is loose and can be wiggled and turned quite easily. It's the one with the red arrow pointing at it just forward of the ECU. The jubilee clip is tight but the plastic bit above it is loose where it goes into the larger black plastic cylinder. There doesn't seem to be any obvious way to tighten it either
Sorry for the lack of technical knowledge but some of this stuff is currently beyond me
Anyone have any ideas or is it safe to ignore?
Thanks,
Pete.
25th May 2015 10:36am |
BykerPete
Brilliant. Thanks for the rapid reply - this really is the best forum out there
Pete.
25th May 2015 10:49am |
