![]() | Home > In Car Electronics > A question for a Memory Map on Android guru (if we have one) |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Have you looked at Memory Map support web pages for Android it is pretty comprehensive, If you cannot find anything to help then visit http://www.memory-map.co.uk/support/ and open a ticket they are pretty quick at replying.
Links to Android help at Memory Map http://www.memory-map.co.uk/support/362850-Android-App Installing the Memory-Map Android app The only way to obtain the Memory-Map app for Android is via Google Play Store(f... How to acquire and download trial maps The latest OS mapping can be easily demoed on your Android device by following t... How to access the OS Great Britain 2015 maps on your Android device You can install the 2015 Ordnance Survey maps to your smartphone or tablet using... Downloading OS Great Britain 2015 maps directly from the Digital Map Shop This article will guide you through the process of downloading your OS Great Bri... Transferring the OS Great Britain 2015 maps to your Android device The OS Great Britain 2015 maps can be sent to Android devices in one of two ways... Transferring the OS Great Britain 2014 maps to your Android device The OS Great Britain 2014 maps can be sent to Android devices in one of two ways... Loading maps to the Internal Storage on Android This article will show you how to transfer mapping that you already have on your... Loading maps to an SD card on Android Android's handling of SD cards is quite complex. The bottom line is, if you put ... Migrating Memory-Map licences for Android If you have a newAndroid deviceand don't want to use your licences/activations o... Recovering DMS mapping on Android This article will guide you through the steps on recovering your mapping purchas... Splitting Maps for Android devices Most Android devicesuse the FAT32 file system. The FAT32 file system has a file ... Transferring marks, routes and tracks from the PC to Android This article will show you how to transfer your marks, routes and tracks saved o... Transferring marks, routes and tracks from Android to the PC This article will show you how to transfer your marks, routes and tracks saved o... About the Nav Data screen This article deals with the Android app Nav screen. Something new in the Android... Android Screen Rotation The Memory-Map Android app can be launched in either portrait or landscape mode,... Classic Map Compatibility and Import 3rd Party Maps explained As Memory-Map has evolved, so has the concept of licensing maps. Two issues that... I get a "file is too large for the destination file system" message when I try to copy my map files to an SD card? If you see this message when trying to copy very large maps to your SD card then... Using Bluetooth and USB GPS units with Memory-Map Android Although many Android units have an integrated GPS, this is not always the case.... Where is the Help file for the Memory-Map Android app? The Help file is available from within the app itself, this can be accessed by: For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
Thanks for the reply!
I have gazed in wonder at the MM support pages and have not (yet) found solace there. What really baffles me is that the whole UK is in a single .qct file, and since mapping for places north of Birmingham is OK that file is clearly being accessed as it should be, and always has until now. I wonder if the file itself has become corrupted perhaps? I will try reinstalling it this evening. It isn't a very useful application when you get a black screen which tells you which way you're heading, and how fast, but not where you are! If reinstalling it doesn't help I will open a ticket. I get so frustrated when these things happen! ![]() Thank you however for your advice. it is much appreciated. |
Have you had a look here as well
http://memory-map.com/mm-android-help3/Memory-Map.htm http://memory-map.com/Knowledge_Base.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Well, I am really baffled now!
I have reinstalled the map file (.qct) from my laptop, I've reinstalled the application from the Google Play store, and it's made no difference whatsoever. As a control, I've done the same thing on a Samsung android tablet that didn't have MM installed and it's worked perfectly (with the same mapping file). I am coming to the conclusion that it's a Sony specific problem. I have raised a ticket with MM, let's hope they can help. Many thanks to everyone who's replied or pm'ed, it is much appreciated. ![]() |
SOLVED ! The good folks at MM have immediately identified the problem.
It seems that Android version 5, know bizarrely as "lollipop" in the way of earlier versions, no longer enables MM to use old-style maps in files larger than 2GB. Since the whole UK in the 2007 edition I am using is 3GB, it doesn't work. Thanks Google! The answer, in case anyone else is in the same situation, is either to upgrade to a later version of the maps (and there are good offers at the moment) or to split your single map into smaller, sub-2GB portions. The latter has got me smiling again. Again, thanks to all who offered advice, much appreciated. ![]() |
Glad you got it sorted. Memory Map has many faults especially with some of its software and particularly with its Adventure 300 GPS unit. However its customer service and support is second to none. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
Obviously you have downloaded the SNP pro-Scottish Independence version. The update factored in the party's recent General election successes and as such has separated the nation's maps for you..... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I did wonder if the ghastly Sturgeon creature had something to do with it!
