Home > Td5 > Help! Hazards, no indicators 53 plate 110 |
Column switch. If you go through life with your head in the sand....all people will see is an ar5e!!
2nd May 2015 5:10pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
You probably need to get a new stalk, easy enough to replace....
http://www.ebay.co.uk/itm/DEFENDER-INDICAT...234ee34814 |
2nd May 2015 5:56pm |
bifterx Member Since: 29 Nov 2014 Location: North Wiltshire Posts: 33 |
Reckon? I'll give it a go. Done forums suggest hazard switch but as it operates ok, I'd sort of discounted it.
Cheers Rob Disco 300TDi XS - Gone Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
2nd May 2015 6:22pm |
tried new column switch. No cigar. Any other thoughts? Thanks rob Disco 300TDi XS - Gone
16th May 2015 1:12pm |
