Home > Puma (Tdci) > Radio Reception
tony2
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Radio Reception
Hi all,
Fitted my Alpine head unit to the defender but FM reception is poor. Is there an alternative aerial that would improve reception, and has anyone else had the same problem?
Cant compair to the origenal head unit as I didnt use it.
Cheers for now..............TC. Thumbs Up Its easy to smile and be happy when the world rolls along like a song.
But a mans got style if he can smile when his Land rovers going wrong.
Post #36661 20th Jul 2010 7:58pm
wyvern
Hi Tony,
this seems to be a regular problem.... I have had the same issue on all the defenders I've owned!
The issue is not with the arial but with the body.. the arial needs a better earth
I put a bonding cable from the bottom of the arial to an earthing point in the engine bay with good results.. cheap and saves all the hastle of removing the arial & cable etc...
Try this before forking out on a new arial. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #36662 20th Jul 2010 8:34pm
tony2
Thanks Wyvern, sounds like a plan to me.
Will give it a try at the weekend.
Chers........TC. Thumbs Up Its easy to smile and be happy when the world rolls along like a song.
Post #36663 20th Jul 2010 8:36pm
Markh
England 2010 Defender 110 Puma 2.4 XS CSW Java Black
wyvern wrote:
Hi Tony,
Wyvern, I've got the same problem and keen to take up your advice, can you give me any tips on what type of cable to use, where to connect etc? Bit of a novice at this so any help would be appreciated....Mark "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #37585 3rd Aug 2010 4:30pm
pom
standard speaker cable is fine, its just to earth it.
Pom
Post #37587 3rd Aug 2010 6:26pm
Markh
Thanks Pom, I'll give it a try "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #37588 3rd Aug 2010 6:42pm
wyvern
Hi Mark H - have you had any luck..? (been away - sorry!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #38383 17th Aug 2010 7:53pm
Markh
Thanks for the followup Wyvern, to be honest not yet! Having investigated under my bonnet due to break cylinder, air conditioning unit gubbins (I think!) can't even get a hand in to the base of the aerial! Wasn't sure how to proceed ....
Any advice? "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #38388 17th Aug 2010 8:21pm
wyvern
from memory (and sitting out in the middle of the north sea with no landy to hand for referance! ) I seemed to remember that I was able to loosen the arial from the outside of the wing with spanner, then clean up the surface with a bit of emmery paper to make a good connenction.
Then feed some earthing cable through the hole to a sutable earth point on the bulkhead which was a screw fitting that I lossend off and then attaced the cable to,
I then stripped back the other end of the cable and lay it arround the bottom of the arieal mount where it was mounted against the body work and re-tighted finger tight first and tested the radio .. tightenting fully when happy that I had a good connection
Caultion - dont undo the arieal completely as it may drop the bottom off .. (if my memory serves me right Wink !)
So give it a go and see.. it cant be any worse Embarassed !
Wyvern Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #38406 17th Aug 2010 9:30pm
K9F
Just a thought but can't you gain access through the wingtop grill/blank by removing the seven screws and getting in there to the aerial? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38407 17th Aug 2010 9:37pm
Markh
Middle of the North sea?! Not ideal landrover territory...
Thanks for the advice tho, going on hols to Cornwall for a couple of weeks (with the landy of course) but will give it a try when I'm back
Thanks again! "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #38408 17th Aug 2010 9:43pm
wyvern
Ahh - well I'm not as techincal as some of you on here - that takes 2 tools for the job and I can only drop one in the engine bay at a time ! Tee hee!
(your dead right and I'm having a Craft Moment ...!)
Enjoy Cornwall Mark ...it was lovely on Monday when I left home !
Shame I'm out here as we could have met up!!
(Yep - I do have a bit of a long commute to work and back) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #38411 17th Aug 2010 10:08pm
Markh
A wet commute by the sounds of it as well! Yes I will
Enjoy thanks, two weeks under canvas, can't beat it... "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #38413 17th Aug 2010 10:19pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
well i have done this and it has made a big difference once i made the connection to the chassie, at first i went straight to the buld head and it was worse, this may be because i have a wireless reversing camera? but once it went on to the chassie big difference, big thanks wyvern.
Post #38433 18th Aug 2010 9:41am
