![]() | Home > Maintenance & Modifications > Electrical failure |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Have you checked the plug was fully secured when you re-fitted?
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Sorry customsteve which plug are you referring to ? I took the binnacle back off but can't see anything amiss
Gavin |
Did you electrically disconnect the binnacle? If so did you refit the plug firmly and securely?
Just saying its a possibility it's loose, or become loose. Last edited by custom90 on 25th Apr 2015 5:02pm. Edited 1 time in total |
Does a TD5 have a megafuse? If not Steve's suggestion sounds favourite, maybe you've inadvertantly disconnected something whilst tinkering. Did you disconnect the battery whilst you were doing it?
Whip the binnacle off and have a route round would be my first avenue. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
knocked a wire off back of ignition switch ?
Thanks guys - yes I'll double check back of binnacle. Just noticed I don't have any instruments either !
I didn't electrically disconnect binnacle but something must be loose or disconnected behind there. Gavin |
Well what do you know. I removed binnacle, checked all connections to it and behind it, checked ignition barrel connections and all seemed OK.
Was going to give up when I decided to do a systematic check of all fuses irrespective of what they were for and eventually found fuse 3 (5A) had blown. The icon in the fuse cover up is an index finger pointing at a book, I had no clue what that was. I changed it and all was well with the world. On looking in the manual it is for battery/diagnostics ! Gavin |
![]() Glad you're sorted. If messing with the binnacle 'best code of practice' would be to disconnect the battery in future perhaps? ![]() Treat every day as if it is your last....one day you will be right!! |
Fully agree !!
