Home > Maintenance & Modifications > Electrical failure
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Electrical failure
Gents
Just had the instrument binnacle off to replace a couple of failed lamps in the instruments.
Consequently I seems to have had a big electrical failure- I have no ignition lamps, no headlamps (sidelights OK), no main beam (though Headlamps do flash) no heated seats, no heated screens, no electric windows. I have checked fuses both np beneath dash and under drivers seat which all seem in order.
Any ideas ? BTW it's a TD5 90.
Gavin
Post #418944 25th Apr 2015 4:46pm
Have you checked the plug was fully secured when you re-fitted?
Post #418945 25th Apr 2015 4:47pm
gavinpm
Sorry customsteve which plug are you referring to ? I took the binnacle back off but can't see anything amiss
Gavin
Post #418946 25th Apr 2015 4:50pm
Did you electrically disconnect the binnacle? If so did you refit the plug firmly and securely?
Just saying its a possibility it's loose, or become loose.
Post #418948 25th Apr 2015 4:52pm
K9F
Does a TD5 have a megafuse? If not Steve's suggestion sounds favourite, maybe you've inadvertantly disconnected something whilst tinkering. Did you disconnect the battery whilst you were doing it?
Whip the binnacle off and have a route round would be my first avenue. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #418951 25th Apr 2015 4:56pm
munch90
knocked a wire off back of ignition switch ?
Post #418953 25th Apr 2015 5:01pm
gavinpm
Thanks guys - yes I'll double check back of binnacle. Just noticed I don't have any instruments either !
I didn't electrically disconnect binnacle but something must be loose or disconnected behind there.
Gavin
Post #418958 25th Apr 2015 5:32pm
gavinpm
Well what do you know. I removed binnacle, checked all connections to it and behind it, checked ignition barrel connections and all seemed OK.
Was going to give up when I decided to do a systematic check of all fuses irrespective of what they were for and eventually found fuse 3 (5A) had blown. The icon in the fuse cover up is an index finger pointing at a book, I had no clue what that was. I changed it and all was well with the world.
On looking in the manual it is for battery/diagnostics !
Gavin
Post #419104 26th Apr 2015 10:50am
K9F
Thumbs Up
Glad you're sorted. If messing with the binnacle 'best code of practice' would be to disconnect the battery in future perhaps?
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419106 26th Apr 2015 10:56am
gavinpm
Fully agree !!
Post #419108 26th Apr 2015 10:59am
