![]() | Home > Puma (Tdci) > Puma gear shift selector guide. Photo? Or part Number? |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
The part you are looking for should be in here somewhere.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
sorry cant help with the part numbers but that is an impressive mileage, have you had any problems with it other than the rattling gear stick DEFENDER 90 TDCI XS,
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
TSC500020 is the gearstick lower assembly, the nylon ball that forms the lever pivot wears allowing movement.
Mogboy Member Since: 22 May 2013 Location: Brisbane Posts: 31 ![]() ![]() ![]() |
Thanks Rakthi for the exploded diagrahm, and 5th Horseman for the part number and direction to the rattle problem. Has anyone sourced the gearstick lower assembly as a Ford Transit part and can comment on price difference?
Thanks LR90XS2011. I've been very happy with the Puma. Plenty of warranty work in the first 100,000kms with build quality issues mainly, but since then it's been pretty low cost and reliable. Some little stuff, but the engine and all the running gear are superb, quiet & efficient...long term keeper I hope. |
I think you'll be out of luck with a transit part, the metal casting is custom made for the Defender application, it includes the support for the transfer gear and diff lock lever and I think the gear lever itself is also unique.
The wear is due to a poor choice of materials for the pivot ball and its carrier (the ball itself seems to be too soft a grade of plastic and wears, whilst the carrier does not seem to). |
Thanks Horseman
That's good information. |
