Home > Puma (Tdci) > Puma gear shift selector guide. Photo? Or part Number?
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
My 2007 Puma has done 270,000km and has developed a rattle in the gearstick. The damper weights on the gear stick are secure and don't rattle, so I suspect it is the selector guide and or actuator end of the gear stick that may be worn.
Could anyone post an exploded diagram, or photo of these parts and/or part numbers please? It will help to confirm parts from my supplier.
Also, despite the kms, mine doesn't appear to have developed any problem with the gearbox output adaptor shaft spline wear. Certainly no gear change clunk. Are there any earlier signs (eg rattle through the gearbox stick?)
Anyone's experience/comments would be appreciated please.
Mogboy
Post #417158 19th Apr 2015 1:32am
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
The part you are looking for should be in here somewhere.
Post #417164 19th Apr 2015 4:13am
LR90XS2011
sorry cant help with the part numbers but that is an impressive mileage, have you had any problems with it other than the rattling gear stick DEFENDER 90 TDCI XS,
Post #417165 19th Apr 2015 4:14am
Fifth Horseman
TSC500020 is the gearstick lower assembly, the nylon ball that forms the lever pivot wears allowing movement.
Post #417184 19th Apr 2015 8:51am
Mogboy
Thanks Rakthi for the exploded diagrahm, and 5th Horseman for the part number and direction to the rattle problem. Has anyone sourced the gearstick lower assembly as a Ford Transit part and can comment on price difference?
Thanks LR90XS2011. I've been very happy with the Puma. Plenty of warranty work in the first 100,000kms with build quality issues mainly, but since then it's been pretty low cost and reliable. Some little stuff, but the engine and all the running gear are superb, quiet & efficient...long term keeper I hope.
Post #417445 19th Apr 2015 10:58pm
Fifth Horseman
I think you'll be out of luck with a transit part, the metal casting is custom made for the Defender application, it includes the support for the transfer gear and diff lock lever and I think the gear lever itself is also unique.
The wear is due to a poor choice of materials for the pivot ball and its carrier (the ball itself seems to be too soft a grade of plastic and wears, whilst the carrier does not seem to).
Post #417667 20th Apr 2015 6:43pm
Mogboy
Thanks Horseman
That's good information.
Post #417810 20th Apr 2015 11:36pm
