![]() | Home > Td5 > 2003 TD5 going up hill lost of power? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
Took a deep hilly ride today with the new MAF sensor...
unlucky the ride was worst then without the sensor plug in (in power side is poor, the car sure more quiet), os what problem can be? or I should just leave the MAF unplug forever??? ![]() |
Check the red plug for oil again ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Will do...heavy rain here now
![]() One question...the MAF sensor connected to the red plug? ![]() something I dont understand... The ECU give out signal to the engine, if the injector harness contain oil...that makes the red plug also oily, so the ECU should not be able to give signal to the engine even the MAF sensor plug or unplug!!! |
