![]() | Home > Maintenance & Modifications > Replacement Rear Door TD5 to Puma? |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Well done both of you !
Sotry if I've missed it, but where did you get the door? |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Hi,
I bought it from SP land rovers in June this year. Worth keeping an eye for them, sometimes they have OEM doors, but my is a proper LR door (eye watering cost). Door part number is:- LR036310 GENUINE DEFENDER 90 110 TD5 ONE PIECE REAR DOOR Cheers Andy |
Hi all,
Just looking to buy some new bits for the rear door. I'm buying the following new:- 1) Windscreen wiper motor - AMR3676 2) Windscreen Wiper Arm - PRC8558 3) Stainless Steel bolts M6 x 25mm (for holding the wiper motor); 4) Stainless Steel bolts for the door Hinges; 5) Hinge refurbishment kit (will put new spring and pins into the hinges at same time as doing the door); 6) Wiring?? 7) Door lock (on its way); ![]() With reference to the wiring loom, can i ask what functionality the new relay brings? My current wiper, does wash and wipe via a switch on the dash (no surprise), my landy is 2001, so I was hoping it would be plug and play, but I'm not so sure!!! Cheers Andy |
![]() Sounds good to me, no point in buying something i don't need. Thanks for the info. Cheers Andy |
Hi all,
Looking for some advice. Have finished building the rear door, i started looking at the hinge holes and the top two holes look like the internal strength member is out of line!! I can move the strength member with a bar if I'm careful, but it springs back into position. Is this a design feature to apply tension to the door hinge bolts somehow, like keeping the door from rattling?? View from outside (top holes) ![]() Click image to enlarge ![]() Click image to enlarge View from inside (top holes) ![]() Click image to enlarge Thanks in advance. Cheers Andy |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2748 ![]() ![]() |
No, just slightly out of place when assembled.
Ok, so not a problem provided i can get the bolts fitted then?
I bought a genuine new door to avoid poo like this! Provided it fits ok, then its alright. Given its painted and assembled, to notice this now is a bit frustrating ![]() Cheers Andy |
Not a problem no. The solution would have been to run an 8.5mm drill through the holes to ensure clearance. However as you say a bit of an issue once painted/finished.
It's a Land Rover panel, poor construction & tolerances is part of the service. |
Hey guys,
Door fitted, no major headaches, just took my time. Enlisted my 11 year old, he did well again ![]() Only issue i have found now is the door lock. Look at the door lock, the key holder is sitting high and not centre of the hole. ![]() Click image to enlarge ![]() Click image to enlarge The is no slop in the holes holding the lock in place. the inly thing i could do is to elongate the bolt holes on the lock. The door does close, but it is hard to close, it needs a good slam, there is no slop in the hinges, i have tightened them all up and replaced the old pins and balls. What can or should i do? I still need to fit the lock barrel to the lock. PS I could try and elongate the striker holes so the striker could be dropped a few mm. Cheers Andy |
