Home > Maintenance & Modifications > Replacement Rear Door TD5 to Puma?
Page 2 of 2 <12
Anderzander
Well done both of you !
Sotry if I've missed it, but where did you get the door?
Post #493212 17th Jan 2016 11:56am
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
I bought it from SP land rovers in June this year.
Worth keeping an eye for them, sometimes they have OEM doors, but my is a proper LR door (eye watering cost).
Door part number is:-
LR036310 GENUINE DEFENDER 90 110 TD5 ONE PIECE REAR DOOR
Andy
Post #493369 17th Jan 2016 7:32pm
ROBBONTHEROCK
Hi all,
Just looking to buy some new bits for the rear door.
I'm buying the following new:-
1) Windscreen wiper motor - AMR3676
2) Windscreen Wiper Arm - PRC8558
3) Stainless Steel bolts M6 x 25mm (for holding the wiper motor);
4) Stainless Steel bolts for the door Hinges;
5) Hinge refurbishment kit (will put new spring and pins into the hinges at same time as doing the door);
6) Wiring??
7) Door lock (on its way);
Cool Torsion bar
With reference to the wiring loom, can i ask what functionality the new relay brings?
My current wiper, does wash and wipe via a switch on the dash (no surprise), my landy is 2001, so I was hoping it would be plug and play, but I'm not so sure!!!
Andy
Post #493409 17th Jan 2016 9:01pm
PaulMc
The (changeover) relay on the tail door harness on 2002 TD5 and Puma Defenders, saves having the live feed from the park switch coming all the way back to the dash switch.
It also simplifies the dash switch wiring, which now simply switches the tail door relay's coil to earth.
If you use a 2002 -> tail door harness, you'll have to change your dash switch.
There's no reason why you can't use your 2001 tail door harness on the 2002 door, and retain your combined rear wash/wipe dash switch.
. Paul.
Post #493430 17th Jan 2016 9:27pm
ROBBONTHEROCK
Thumbs Up
Sounds good to me, no point in buying something i don't need.
Thanks for the info.
Andy
Post #493459 17th Jan 2016 10:15pm
ROBBONTHEROCK
Hi all,
Looking for some advice.
Have finished building the rear door, i started looking at the hinge holes and the top two holes look like the internal strength member is out of line!!
I can move the strength member with a bar if I'm careful, but it springs back into position.
Is this a design feature to apply tension to the door hinge bolts somehow, like keeping the door from rattling??
View from outside (top holes)
View from inside (top holes)
Thanks in advance.
Andy
Post #495406 23rd Jan 2016 12:21am
Retroanaconda
No, just slightly out of place when assembled.
Post #495420 23rd Jan 2016 1:34am
ROBBONTHEROCK
Ok, so not a problem provided i can get the bolts fitted then?
I bought a genuine new door to avoid poo like this!
Provided it fits ok, then its alright.
Given its painted and assembled, to notice this now is a bit frustrating Big Cry
Andy
Post #495433 23rd Jan 2016 7:51am
Retroanaconda
Not a problem no. The solution would have been to run an 8.5mm drill through the holes to ensure clearance. However as you say a bit of an issue once painted/finished.
It's a Land Rover panel, poor construction & tolerances is part of the service.
Post #495461 23rd Jan 2016 10:34am
ROBBONTHEROCK
Hey guys,
Door fitted, no major headaches, just took my time.
Enlisted my 11 year old, he did well again Wink
Only issue i have found now is the door lock.
Look at the door lock, the key holder is sitting high and not centre of the hole.
The is no slop in the holes holding the lock in place. the inly thing i could do is to elongate the bolt holes on the lock.
The door does close, but it is hard to close, it needs a good slam, there is no slop in the hinges, i have tightened them all up and replaced the old pins and balls.
What can or should i do?
I still need to fit the lock barrel to the lock.
PS I could try and elongate the striker holes so the striker could be dropped a few mm.
Andy
Post #495596 23rd Jan 2016 8:10pm
Page 2 of 2 <12
