![]() | Home > Puma (Tdci) > Rear diff oil spec |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
Good old EP90
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
Castrol Syntrax Long Life 75w-90 (Replaces Castrol SAF-XO)
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
No, That's 'old school' Landies. 75W/90 as Theater says ... ![]() |
I-Landy Member Since: 28 Jan 2015 Location: Bournemouth Posts: 35 ![]() ![]() ![]() |
80w/90? Seems to be called Gear oil/Diff oil...or is it definitely 75w/90?
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 243 ![]() ![]() ![]() |
I have had the same discussions with Opie Oils
I will be using Fuchs Titan Syn 5 in my diffs and transfer box And Castrol Syntrans Multivehicle 75w-90 in the gearbox From Opie "The Syn 5 isn't always great as a gear oil as it can be too slippery and not slow the synchros enough, it's best to use that for the diffs and transfer box and then the Syntrans Multivehicle for the gearbox" I changed the gearbox oil in my Hilux - the hand book recommended either a 80w-90 or 75w-90. The original fill was 80w-90, so this is what i initially refilled the box with, cold winter down to -4 degrees for 6 weeks and the box was terrible, so I dropped the oil again and put 75w-90 and the box gear chang is a sweet as can be (still same 2 years later) no matter what the temp |
