Home > Puma (Tdci) > Rear diff oil spec
I-Landy
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Rear diff oil spec
Hi,
I have a 57 defender tdci, noticed a bit of a leak around the prop shaft/rear diff. Guessing it's an oil seal...in the meantime, I should probably top the rear diff oil up, anyone know the spec for the diff oil?
Much appreciated
Post #411493 27th Mar 2015 7:26pm
ibexman
Good old EP90 Whistle
Post #411511 27th Mar 2015 8:15pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Castrol Syntrax Long Life 75w-90 (Replaces Castrol SAF-XO)
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #411547 27th Mar 2015 10:25pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
No, That's 'old school' Landies.
75W/90 as Theater says ... Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #411550 27th Mar 2015 10:47pm
I-Landy
80w/90? Seems to be called Gear oil/Diff oil...or is it definitely 75w/90?
Post #411709 28th Mar 2015 3:05pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I have had the same discussions with Opie Oils
I will be using Fuchs Titan Syn 5 in my diffs and transfer box
And Castrol Syntrans Multivehicle 75w-90 in the gearbox
From Opie
"The Syn 5 isn't always great as a gear oil as it can be too slippery and not slow the synchros enough, it's best to use that for the diffs and transfer box and then the Syntrans Multivehicle for the gearbox"
I changed the gearbox oil in my Hilux - the hand book recommended either a 80w-90 or 75w-90. The original fill was 80w-90, so this is what i initially refilled the box with, cold winter down to -4 degrees for 6 weeks and the box was terrible, so I dropped the oil again and put 75w-90 and the box gear chang is a sweet as can be (still same 2 years later) no matter what the temp
Post #411715 28th Mar 2015 3:25pm
