|  | Home > Technical > Advice Gents... |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675      |
 Anyone know where I can pick up a ignition live in the engine bay of a 2.2 Puma.
 Cheers Mac....  | ||
|  24th Mar 2015 6:23pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Have a look at Dgardel's downloads.     https://onedrive.live.com/?cid=4bc2d89c85c...m9sigoZ_Zk Workshop Public Tab!  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  24th Mar 2015 7:24pm |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675      | Cheers K9,
 I've looked and looked and looked some more...Still none the wiser. | ||
|  24th Mar 2015 8:57pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Electrical Diagrams.....    I know it says LHD but the colours are the same if you can read them.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  24th Mar 2015 8:59pm |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675      | I actually nodded off looking through the diagrams...    I'll get the multimeter out and start stabbing wires. | ||
|  25th Mar 2015 4:19pm |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422    | Hold on. MAC 22. Before you go off stabbing wires at will. What are you powering ?
 You may well pull to large a current thru something and cost yourself thousands. On a more professional route, may be use your ignition feed to trigger a relay, which will receive a power supply directly from the battery. Excuse the spelling I`am better with spanners and wires. | ||
|  25th Mar 2015 6:54pm |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675      | Hi Martin
 The feed will be powering the DRLs which is fused and rated @ 5 amps. So the draw is quite small. | ||
|  25th Mar 2015 10:53pm |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568    | I good point about current draw, I used mine too power the most excellent cruise control from Mobile Centre. I think it had a one amp fuse! I would with five amps be inclined to a direct battery feed and a relay ( Fused) combined OEM switch using a current blank on the dash.   | ||
|  26th Mar 2015 3:08am |
| Gunbus Member Since: 16 Mar 2015 Location: Argyll Posts: 46      |
 I have taken an ignition feed from the cable that supplies the heater fan motor. There is only 2 - cant remember from memory what color! You can verify the voltage without stabbing the cables by probing the connection point. Its located on the passenger side at the bulkhead. Cable for DRL routed up the inner wing behind the washer bottle. | ||
|  30th Mar 2015 1:40pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | are you using a drl controller ? | ||
|  30th Mar 2015 1:59pm |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678    | If you are using a DRL controller you shouldn't need an ignition feed
 If you are not using one bear in mind it is illegal for your DRL's to run at full brightness at the same time as your sidelights | ||
|  30th Mar 2015 2:30pm |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328    | Fan Blower is ig live     I would post a pic but its a test fit so it scotch locked on  Heat shrink later this week | ||
|  30th Mar 2015 2:31pm |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675      | Cheers Guys..
 Ken, I think the wires to the blower are orange and errr, it was dark when trying to meter them.on my own... Which is the live. Cheers. | ||
|  1st Apr 2015 12:53pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
