![]() | Home > Technical > Advice Gents... |
| Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675
Anyone know where I can pick up a ignition live in the engine bay of a 2.2 Puma.
Cheers Mac.... |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Have a look at Dgardel's downloads.
https://onedrive.live.com/?cid=4bc2d89c85c...m9sigoZ_Zk Workshop Public Tab! Treat every day as if it is your last....one day you will be right!! |
Cheers K9,
I've looked and looked and looked some more...Still none the wiser. |
Electrical Diagrams.....
I know it says LHD but the colours are the same if you can read them. Treat every day as if it is your last....one day you will be right!! |
I actually nodded off looking through the diagrams...
I'll get the multimeter out and start stabbing wires. |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422
Hold on. MAC 22. Before you go off stabbing wires at will. What are you powering ?
You may well pull to large a current thru something and cost yourself thousands. On a more professional route, may be use your ignition feed to trigger a relay, which will receive a power supply directly from the battery. Excuse the spelling I`am better with spanners and wires. |
Hi Martin
The feed will be powering the DRLs which is fused and rated @ 5 amps. So the draw is quite small. |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
I good point about current draw, I used mine too power the most excellent cruise control from Mobile Centre. I think it had a one amp fuse! I would with five amps be inclined to a direct battery feed and a relay ( Fused) combined OEM switch using a current blank on the dash.
| Gunbus Member Since: 16 Mar 2015 Location: Argyll Posts: 46
I have taken an ignition feed from the cable that supplies the heater fan motor. There is only 2 - cant remember from memory what color! You can verify the voltage without stabbing the cables by probing the connection point. Its located on the passenger side at the bulkhead. Cable for DRL routed up the inner wing behind the washer bottle. |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
are you using a drl controller ?
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
If you are using a DRL controller you shouldn't need an ignition feed
If you are not using one bear in mind it is illegal for your DRL's to run at full brightness at the same time as your sidelights |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Fan Blower is ig live
I would post a pic but its a test fit so it scotch locked on |
Cheers Guys..
Ken, I think the wires to the blower are orange and errr, it was dark when trying to meter them.on my own... Which is the live. Cheers. |
| All times are GMT |
