Home > Technical > Suspension height
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Suspension height
I think I may have a droopy front end........and I don't think it's my age.
I have 110 Puma DC which seems unnaturally low at the front. I know they are usually orientated with the rear up but the front just seems TOO low. Could some kindly soul measure their front suspension height for comparison. Under the front bumper would be ideal, or alternatively to the wheel arch.
If the height is about right I will invest in some plus one springs for the front but if they are simply sagging through age I will get some new standard ones..........
Dave
Post #409130 19th Mar 2015 10:32pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
If I remember I'll measure mine for you, but may be lower anyway due to the extra weight of a HD bumper and steering guard.
But they do sit 'arse up' naturally, heavier duty springs on the back for taking loads than on the front. I bought a pair of standard 90 rear springs to fit up front as some on here have said it'll level it up better.
 Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #409150 20th Mar 2015 12:44am
landy andy
Mind is low on the front due to added toys, so can't help. Sorry
Post #409158 20th Mar 2015 7:01am
kipperthedog
If you look at your springs, which are a 2 stage weight as standard, you nmay find the first 3(ish) coils are compressed. This is the softer part of the spring. Mine were like this. I replaced with 90 rears (also 110 HD fronts, is the same spring), but new standard fronts would have made a difference. If the softer cioils are not under compression they are probably ok!
Post #409186 20th Mar 2015 8:45am
Venomator
Re: Suspension height
Dave
Approx 51cms to underside of bumper Dave... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #409231 20th Mar 2015 11:49am
