![]() | Home > Technical > Suspension height |
| PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468
If I remember I'll measure mine for you, but may be lower anyway due to the extra weight of a HD bumper and steering guard.
But they do sit 'arse up' naturally, heavier duty springs on the back for taking loads than on the front. I bought a pair of standard 90 rear springs to fit up front as some on here have said it'll level it up better. Click image to enlarge Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048
Mind is low on the front due to added toys, so can't help. Sorry
Click image to enlarge |
| kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403
If you look at your springs, which are a 2 stage weight as standard, you nmay find the first 3(ish) coils are compressed. This is the softer part of the spring. Mine were like this. I replaced with 90 rears (also 110 HD fronts, is the same spring), but new standard fronts would have made a difference. If the softer cioils are not under compression they are probably ok!
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
Approx 51cms to underside of bumper Dave... Click image to enlarge Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
