Home > Maintenance & Modifications > Bonnet Buffers
Bonnet Buffers
Noticed whilst I was changing out the rusted grill screws that the bonnet buffer was a little short and the vibrating had rubbed away the paint on one side.
When I went to adjust it to make it a little longer, there didn't seem much thread left, so I decided to, clean the area, add a dab of paint and then use a felt pad to ensure it doesn't happen again.
Might be worth checking yours - is there freeplay in the bonnet front corners when closed?
Post #408454 17th Mar 2015 6:15pm
They can be an un-even in load.
I find the best way to adjust is to shut the bonnet, put a finger under and adjust until the stop is against the body.
Post #408474 17th Mar 2015 7:17pm
