Home > Puma (Tdci) > Gear Stick Wobble
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Gear Stick Wobble
There are a few posts that mention things about gear stick rattles but the problem I have is with the gear stick wobbling/vibrating quite severely when in 6th over 60mph. No other symptoms whatsoever!
I thought at first this was the road surface as things move around depending on the surface, the gear stick wobble is still happening though on a perfectly smooth road. Another possible cause is whether there is a wheel out of balance but I dont think it's that.
Has anyone else seen this issue and know what the resolution was? I dont think it's anything serious Confused 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #35327 29th Jun 2010 6:40pm
RED-DOT
I got a new gearstick fitted under warranty and it was as yours is... 6th gear 60+. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #35330 29th Jun 2010 7:12pm
mrwoo
Great thanks RED-DOT - did that cure the problem? 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #35333 29th Jun 2010 7:35pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
I had the same problem. New gearstick assembly sorted it.
Post #35342 29th Jun 2010 8:49pm
mrwoo
What mileages were yours at? Mine has only done 5k?
Cheers 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #35369 30th Jun 2010 8:02am
Grockle
I think MSE has had this, there is a mod re selector fork 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #35370 30th Jun 2010 8:08am
Higgers
About 9000 but ignored it until about 20,000!
Post #35376 30th Jun 2010 9:34am
mse
Very similar - there is a technical reference for detents thats one.
All you need to do is change the selector guide - not the whole unit - its probably something silly like a build flaw that wears the original, which means the new part correctly fitted cures it...like i said in previous posts - it did for me UNTIL the idiots broke the selector and i was back to square 1.
If they did what i advised (change the guide) then that would explain what it seems like its fixed. Mike
Post #35395 30th Jun 2010 5:53pm
RED-DOT
Mr Woo... YES, my new gearstick at 6,0000m cured the rattle 100%. "Morrisons" were in possesion af a bulletin to renew if customer complained and the ball end of the stick was badly machined. It drove me crazy on a 400 mile trip and i believe the selectors are not an issue. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #35398 30th Jun 2010 7:18pm
mse
I agree its not the selectors, but the guide Mike
Post #35399 30th Jun 2010 7:27pm
mrwoo
Thanks for all the advice guys, it's in today so I'll up date you later on the outcome. 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #35413 1st Jul 2010 9:01am
mrwoo
Well chaps and for future reference when your knob starts to rattle Very Happy , LR have admitted there is a problem and ordered a new selector guide. Soon as it's fitted I will give you another update. 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #35442 1st Jul 2010 9:22pm
fekete
The problem is the selector guide is made of plastic so it will wear again Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #35447 1st Jul 2010 9:39pm
mrwoo
Have you had your's replaced Fekete? 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #35448 1st Jul 2010 10:15pm
fekete
They replaced the Gearbox because of this and bad selection NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #35457 2nd Jul 2010 8:05am
