![]() | Home > Puma (Tdci) > Gear Stick Wobble |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I got a new gearstick fitted under warranty and it was as yours is... 6th gear 60+. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Great thanks RED-DOT - did that cure the problem? 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672 ![]() ![]() ![]() |
I had the same problem. New gearstick assembly sorted it.
What mileages were yours at? Mine has only done 5k?
Cheers 1964 Series IIA SWB Truck Cab - gone 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
I think MSE has had this, there is a mod re selector fork 2.4 90 XS
About 9000 but ignored it until about 20,000!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Very similar - there is a technical reference for detents thats one. All you need to do is change the selector guide - not the whole unit - its probably something silly like a build flaw that wears the original, which means the new part correctly fitted cures it...like i said in previous posts - it did for me UNTIL the idiots broke the selector and i was back to square 1. If they did what i advised (change the guide) then that would explain what it seems like its fixed. Mike |
Mr Woo... YES, my new gearstick at 6,0000m cured the rattle 100%. "Morrisons" were in possesion af a bulletin to renew if customer complained and the ball end of the stick was badly machined. It drove me crazy on a 400 mile trip and i believe the selectors are not an issue. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
I agree its not the selectors, but the guide Mike |
Thanks for all the advice guys, it's in today so I'll up date you later on the outcome. 1964 Series IIA SWB Truck Cab - gone
Well chaps and for future reference when your knob starts to rattle
![]() 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
The problem is the selector guide is made of plastic so it will wear again
Have you had your's replaced Fekete? 1964 Series IIA SWB Truck Cab - gone 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
They replaced the Gearbox because of this and bad selection NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
