![]() | Home > Maintenance & Modifications > WIPAC LED Light Upgrade |
BIGJOCK90 Member Since: 26 Jan 2015 Location: Wallacestone Posts: 7 ![]() ![]() ![]() |
Hi
Recently fitted Wipac LED light upgrades to my 90 HT and the brake lights are not working now anybody got any ideas what this could be???? ![]() |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Jock
Just fitted these to with no issues, have you tried the original lamps to rule out your brake light switch? Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Hi John,
Yeah just been out checking the fuse for the switch also and i plugged in the trailer and the brake lights not working on it either so i reckon its the switch. Thanks for your speedy response. Cheers Jock |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5132 ![]() ![]() ![]() |
LED lights are polarity sensitive. Land Rover changed the orientation of the positive and negative leads in the indicator and sidelight connectors around 1998. If your vehicle was built after this date you may need to switch the connector pins in the plug. This is very easy to do and only needs to be done on the indicators and sidelights. It is quite safe to try the lights on your vehicle first; no damage will be done to the vehicle wiring or the lights. If you try one of the lights and it does not work, you will need to change the pins around in the connector plugs on the lights themselves. Alternatively you can cut the wires and re-join them to the right positive and neg.
I know this the case with sidelights and indicators so it may also be true for stop lights. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
