Home > Maintenance & Modifications > WIPAC LED Light Upgrade
BIGJOCK90
United Kingdom 2008 Defender 90 Puma 2.4 HT Zermatt Silver
Hi
Recently fitted Wipac LED light upgrades to my 90 HT and the brake lights are not working now anybody got any ideas what this could be???? Thumbs Up
Post #405686 8th Mar 2015 7:17pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Jock
Just fitted these to with no issues, have you tried the original lamps to rule out your brake light switch?
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #405687 8th Mar 2015 7:19pm
BIGJOCK90
Hi John,
Yeah just been out checking the fuse for the switch also and i plugged in the trailer and the brake lights not working on it either so i reckon its the switch. Thanks for your speedy response.
Jock
Post #405701 8th Mar 2015 7:44pm
gilarion
LED lights are polarity sensitive. Land Rover changed the orientation of the positive and negative leads in the indicator and sidelight connectors around 1998. If your vehicle was built after this date you may need to switch the connector pins in the plug. This is very easy to do and only needs to be done on the indicators and sidelights. It is quite safe to try the lights on your vehicle first; no damage will be done to the vehicle wiring or the lights. If you try one of the lights and it does not work, you will need to change the pins around in the connector plugs on the lights themselves. Alternatively you can cut the wires and re-join them to the right positive and neg.
I know this the case with sidelights and indicators so it may also be true for stop lights. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405705 8th Mar 2015 7:47pm
