![]() | Home > Puma (Tdci) > Are Defender TD5 Style Headlamp Surrounds same as Puma? |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
Are TD5 Style Headlamp Surrounds the same as TDci ones (same as in the link below)?
http://www.jgs4x4.co.uk/land-rover-defende...1078-p.asp Looking to replace my grey ones with black ones. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Yes.
No.
Although (later) TDCi are only slightly different in that they have an additional screw hole (bottom right hand side of right hand panel and vice versa on left hand side) |
So is it yes or no?
Mine is 2.4 59 plate.... |
If you have three existing screw holes then you'll need to drill an additional one in the TD5 ones, if you haven't then they'll be the same
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
According to Microcat Defender up to 2007 and from 2007 the headlight finisher has the same part numbers
Right DHH 1007780PUC Left DHH 1007790PUC For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 Last edited by gilarion on 2nd Mar 2015 6:12pm. Edited 2 times in total |
Not sure when the cross over year was but my 2007 has two holes as does my 2009 but my 2014 has three ...
Models that pre date the TD5 have a different part number due to them not having the louver slots cut out in them.
Someone told me once the cut outs were to assist engine cooling don't know if that is true. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
This is off a 2014 model (note the additional hole bottom right).
The louvers are to let out the sound from the horns [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Excellent, I have only 2 holes so that clears that up! Thanks for your help everybody!
No worries
![]() Whereabouts in Kent are you ? |
Is that true? For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Some 5 miles from Bluewater so not far from Headcorn.
For your information I am also the commentator for the SLSLRC London to Brighton run for the last 10 years!! |
Yes !
They are sited just behind the louvres |
