Home > Puma (Tdci) > Are Defender TD5 Style Headlamp Surrounds same as Puma?
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Are TD5 Style Headlamp Surrounds the same as TDci ones (same as in the link below)?
http://www.jgs4x4.co.uk/land-rover-defende...1078-p.asp
Looking to replace my grey ones with black ones.
Post #403705 2nd Mar 2015 3:53pm
Yes.
Post #403707 2nd Mar 2015 3:59pm
No.
Although (later) TDCi are only slightly different in that they have an additional screw hole (bottom right hand side of right hand panel and vice versa on left hand side)
Post #403711 2nd Mar 2015 4:06pm
DonH2000
So is it yes or no?
Mine is 2.4 59 plate....
Post #403716 2nd Mar 2015 4:24pm
If you have three existing screw holes then you'll need to drill an additional one in the TD5 ones, if you haven't then they'll be the same
Post #403722 2nd Mar 2015 4:59pm
gilarion
According to Microcat Defender up to 2007 and from 2007 the headlight finisher has the same part numbers
Right DHH 1007780PUC
Left DHH 1007790PUC For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #403723 2nd Mar 2015 5:07pm
Not sure when the cross over year was but my 2007 has two holes as does my 2009 but my 2014 has three ...
Post #403725 2nd Mar 2015 5:09pm
leeds
Well I have got some take off ones from a Puma here and they look identical to the ones in the photo you have linked to.
These panels are held in place by the side light and indicator lights screws plus two screws on the inside of the headlight which fasten onto some square plastic plugs.
If you want to fit certain brands of headlight protectors you need to drill two extra holes in the plastic surrounds which corresponds to two square holes in the wing. You need to insert square plastic plugs into the wing. I have some of the plastic plugs available if you need them.
HTH
Brendan
Post #403727 2nd Mar 2015 5:13pm
gilarion
Models that pre date the TD5 have a different part number due to them not having the louver slots cut out in them.
Someone told me once the cut outs were to assist engine cooling don't know if that is true. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #403728 2nd Mar 2015 5:14pm
This is off a 2014 model (note the additional hole bottom right).
The louvers are to let out the sound from the horns
Post #403730 2nd Mar 2015 5:17pm
DonH2000
Excellent, I have only 2 holes so that clears that up! Thanks for your help everybody!
Post #403733 2nd Mar 2015 5:23pm
No worries Thumbs Up
Whereabouts in Kent are you ?
Post #403734 2nd Mar 2015 5:24pm
gilarion
Is that true? For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #403736 2nd Mar 2015 5:28pm
DonH2000
Some 5 miles from Bluewater so not far from Headcorn.
For your information I am also the commentator for the SLSLRC London to Brighton run for the last 10 years!!
Post #403738 2nd Mar 2015 5:30pm
Yes !
They are sited just behind the louvres
Post #403739 2nd Mar 2015 5:30pm
