![]() | Home > Maintenance & Modifications > G4 Roof Rack |
stu_007 Member Since: 23 Jan 2014 Location: Cardiff Posts: 99 ![]() ![]() |
That looks like a Safety Devices rack, so contact them direct to see what they suggest. SD supplied the original racks for the 2003 event and Breed made the ones for 2006. Obviously there were no genuine D90s on the event or ones with the roll over hoop; these are Limited Editions . Current
2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
Dutch G4 Member Since: 29 Jan 2015 Location: near Rotterdam Posts: 49 ![]() ![]() |
Thanks Stu, i will contact them; i had already found the Rack on the website of Safety Devices and they say:
Full luggage rail 'G4 Expedition' roof rack for mounting to rain gutter (this roof rack cannot be fitted to a vehicle where an external roll cage has been fitted). but i'll ask anyway - mabye they have a suggestion ! Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Have you enquired about Genuine Part Number BA3190.
This is the LR part number for the original G4 (aka Challenge) roof rack but not sure about the roll cage clearance. I know Bearmach make (or used to make) a version of this rack. Looking at the photo, I'm guessing that it will fit (and so will the others mentioned), however, you will have to remove the roll cage to fit it and then reinstall the cage over the top. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 ![]() ![]() ![]() |
The original 2003 G4 rack is from safety devices not LR. The 2006 challenge Defenders had a similar rack but from another company.
Zooming in on the picture it shows the safety devices G4 rack just clears where the external cage meets the roof. Due to your location I doubt the trial and error approach will work. Definatly speak to Safety Devices as they've been really helpful as I return mine to full G4 spec. Strong people are harder to kill and generally more useful! |
yes, i have found the partno. BA 3190 on the website of John Craddock as well but i just want to be sure that the rack
would fit.... ![]() |
