Home > Maintenance & Modifications > G4 Roof Rack
Dutch G4
Netherlands
G4 Roof Rack
Question please: i want to install a roof rack on my G4 (if possible the same one as on the example pictures here below), i have asked several suppliers in NL & UK but they all say it is not possible to fix this type of rack because of the roll cage but as you can see on the pics below it should be possible, maybe with some adjustments ? Can anyone help out
please and /or suggest which roof rack can be fitted with a roll cage?
 Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #397319 9th Feb 2015 3:33pm
stu_007
That looks like a Safety Devices rack, so contact them direct to see what they suggest. SD supplied the original racks for the 2003 event and Breed made the ones for 2006. Obviously there were no genuine D90s on the event or ones with the roll over hoop; these are Limited Editions . Current
2021 D110 HSE
2013 D90 XS
Previous
BP07 OZR D110 (1930 YBA)
2007 G4 Mongolian Recce Vehicle
BP52GHZ D110
2003 & 2006 G4 Event Vehicle
Post #397325 9th Feb 2015 4:01pm
Dutch G4
Netherlands
Thanks Stu, i will contact them; i had already found the Rack on the website of Safety Devices and they say:
Full luggage rail 'G4 Expedition' roof rack for mounting to rain gutter (this roof rack cannot be fitted to a vehicle where an external roll cage has been fitted).
but i'll ask anyway - mabye they have a suggestion !
Post #397330 9th Feb 2015 4:19pm
x-isle
Have you enquired about Genuine Part Number BA3190.
This is the LR part number for the original G4 (aka Challenge) roof rack but not sure about the roll cage clearance. I know Bearmach make (or used to make) a version of this rack.
Looking at the photo, I'm guessing that it will fit (and so will the others mentioned), however, you will have to remove the roll cage to fit it and then reinstall the cage over the top. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #397332 9th Feb 2015 4:28pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
The original 2003 G4 rack is from safety devices not LR. The 2006 challenge Defenders had a similar rack but from another company.
Zooming in on the picture it shows the safety devices G4 rack just clears where the external cage meets the roof. Due to your location I doubt the trial and error approach will work.
Definatly speak to Safety Devices as they've been really helpful as I return mine to full G4 spec. Strong people are harder to kill and generally more useful!
Post #397338 9th Feb 2015 4:45pm
Dutch G4
Netherlands
yes, i have found the partno. BA 3190 on the website of John Craddock as well but i just want to be sure that the rack
would fit.... Confused I have just sent a mail to Safety Devices, i will post their reply later on Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #397340 9th Feb 2015 4:48pm
