![]() | Home > Puma (Tdci) > Probably the definitive Puma clutch solution |
HD rate, installed on transit 2.4 4x4 (MT82).
A friend of my from Germany has installed it and it fit perfectly It seems very strong (for sure strongest than the B&B, Valeo or AP) http://www.autoteiletrend.de/3000-950-727-...nd?c=16467 ![]() Click image to enlarge ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Standard fit self adjusting clutch, as fitted to most transits. They last well as the dual mass flywheel takes all the flack.
However with out the dual mass flywheel the centre of the friction plate still gets hammered. When the dual mass flywheel conversion kit comes out ( some ones bound to make a tranny one fit), I`ll have one of them. Excuse the spelling I`am better with spanners and wires. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
I love the fact everyone slagged off the Td5 because of having a DMF. Now the defender doesn't everyone wants to fit one.
Andy |
[quote="dgardel"]HD rate, installed on transit 2.4 4x4 (MT82).
A friend of my from Germany has installed it and it fit perfectly It seems very strong (for sure strongest than the B&B, Valeo or AP) http://www.autoteiletrend.de/3000-950-727-...nd?c=16467 ![]() Click image to enlarge ![]() Click image to enlarge[/quo shood be fitted as standed in all transit ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2499 ![]() ![]() ![]() |
A friend of my from Germany has installed it and it fit perfectly It seems very strong (for sure strongest than the B&B, Valeo or AP) http://www.autoteiletrend.de/3000-950-727-...nd?c=16467 If it does not have the central smaller damper, pilot shaft will clatter for sure. Puma 110" SW ............................................................. Earth first. Other planets later |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
How is the clutch lasting? Any news I'm in the market for a new HD one. |
