Home > Puma (Tdci) > Probably the definitive Puma clutch solution
dgardel
Italy
HD rate, installed on transit 2.4 4x4 (MT82).
A friend of my from Germany has installed it and it fit perfectly
It seems very strong (for sure strongest than the B&B, Valeo or AP)
http://www.autoteiletrend.de/3000-950-727-...nd?c=16467
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #394271 31st Jan 2015 12:32am
HardCharger
Is this more expensive or just the same price? Mine is due soon as it already rattles every now and then. I was told to change this and the carrier bearing (?). Anything else?
Post #394286 31st Jan 2015 4:17am
martinfiattech
Standard fit self adjusting clutch, as fitted to most transits. They last well as the dual mass flywheel takes all the flack.
However with out the dual mass flywheel the centre of the friction plate still gets hammered.
When the dual mass flywheel conversion kit comes out ( some ones bound to make a tranny one fit), I`ll have one of them. Excuse the spelling I`am better with spanners and wires.
Post #394412 31st Jan 2015 2:59pm
landy andy
I love the fact everyone slagged off the Td5 because of having a DMF. Now the defender doesn't everyone wants to fit one.
Andy
Post #394471 31st Jan 2015 6:23pm
dorsetsmith
Re: Probably the definitive Puma clutch solution
[quote="dgardel"]HD rate, installed on transit 2.4 4x4 (MT82).
[/quo
shood be fitted as standed in all transit Laughing
Post #394481 31st Jan 2015 6:37pm
MK
If it does not have the central smaller damper, pilot shaft will clatter for sure. Puma 110" SW
Post #394802 1st Feb 2015 3:01pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
How is the clutch lasting?
Any news
I'm in the market for a new HD one.
Post #470245 6th Nov 2015 10:56pm
