![]() | Home > Puma (Tdci) > Coolant Top Up |
That's not unusual, so I wouldn't worry about it at all. Along as you're not constantly doing it, and therefore diluting the coolant in a significant way, a it's fine.
![]() Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Try a new cap if you have to top up frequently. If you do a search you will find it is a common problem and fix.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
All my defenders have always been constantly lower than the level line. If I top up, it pushes a bit out and sits at the level you mention.
Andy |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 463 ![]() ![]() ![]() |
Mine has lost about 1 cm regularly since new, slightly more if I ignore it for a year. Now nearly 2 yrs old and 21K miles.
Did go back to the stealer a couple of times originally but they never found any reason or cure. Seems to be something it's OK to live with. Cheers. 2.2 90 XS 88" Series One Old Norton ![]() Modern Honda and Harley |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
Gum, I topped it up with coolant not water as we had a bottle from when my RCZ sprang a leak. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
Check your power steering fluid too ... Some new cars have just enough
