Home > Puma (Tdci) > Coolant Top Up
CatherineF
Coolant Top Up
Has anyone had top up their coolant?
We were under the bonnet today and noticed that cold it was below the cold level by about 1cm, so we gave it a bit of a top up. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #392448 25th Jan 2015 6:11pm
GUM97
That's not unusual, so I wouldn't worry about it at all. Along as you're not constantly doing it, and therefore diluting the coolant in a significant way, a it's fine. Thumbs Up
Pete An engine to TDi for!
Post #392456 25th Jan 2015 6:18pm
driver9
Try a new cap if you have to top up frequently. If you do a search you will find it is a common problem and fix.
Post #392458 25th Jan 2015 6:21pm
landy andy
All my defenders have always been constantly lower than the level line. If I top up, it pushes a bit out and sits at the level you mention.
Andy
Post #392468 25th Jan 2015 6:44pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Mine has lost about 1 cm regularly since new, slightly more if I ignore it for a year. Now nearly 2 yrs old and 21K miles.
Did go back to the stealer a couple of times originally but they never found any reason or cure. Seems to be something it's OK to live with.
Cheers. 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #392506 25th Jan 2015 7:34pm
CatherineF
Pete
Gum, I topped it up with coolant not water as we had a bottle from when my RCZ sprang a leak. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #392514 25th Jan 2015 7:55pm
Check your power steering fluid too ... Some new cars have just enough
Post #392569 25th Jan 2015 9:40pm
