Home > Maintenance & Modifications > Water in seat box
Andyred90
Water in seat box
I went to sort out an earth fault on a TD5 and when I opened the seat box under the drivers seat it had 1/2 inch of water sloshing around!
I think this possibly got into the seat box from the rear tub as my truck was a pick up until a few mays ago when I fitted a hard top and water collected in the tub against the bulk head as the grommets where the wires enter the seat box all look ok with no sign of water marks.
The seat box was dried out but any views on whether I should make a drain hole as the seat box where the battery sits has a couple of holes in the base?
Andy
Post #380593 20th Dec 2014 11:59pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Save yourself hours of frustration trying to seal the box....drill a big drain hole Laughing 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #380596 21st Dec 2014 12:18am
Andyred90
That's the plan but just wanted to see if there is any reason not to do that before getting the drill out!
Post #380619 21st Dec 2014 9:31am
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
If you drill a drain hole then this is also a water entry point. So if you do any wading then water will enter and I dont think the computer would like to be covered in water too much.
I would try and find an alternate solution to this problem. Shocked 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #380621 21st Dec 2014 9:36am
dorsetsmith
duck tape Rolling with laughter Thumbs Up
Post #380624 21st Dec 2014 9:53am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Post #380637 21st Dec 2014 10:44am
