![]() | Home > Maintenance & Modifications > Water in seat box |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Save yourself hours of frustration trying to seal the box....drill a big drain hole
![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 ![]() ![]() |
That's the plan but just wanted to see if there is any reason not to do that before getting the drill out!
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 ![]() ![]() ![]() |
If you drill a drain hole then this is also a water entry point. So if you do any wading then water will enter and I dont think the computer would like to be covered in water too much.
I would try and find an alternate solution to this problem. ![]() 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
duck tape
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Try a yrm double battery tray.
http://www.yrmlandrover.com/epages/BT3575..../037B-0001 |
