Home > Technical > Weird Mamba antics this morning... :(
Page 1 of 3 123>
Venomator
This happened to me just this morning... Big Cry
My Mamba did a weird number of cycles first thing;
It would start okay, but within 15-20 seconds this palaver went on...
Temp Gauge shot off the high end;
Rev Counter zeroed;
Battery indicator stayed on;
Accelerator did not work properly.
When depressing the accelerator it would not react as normal straight away, but when it did it carried on revving higher and then took ages to drop back down!
Finally cleared itself after half a dozen stop, lock, start routines only to then be left with the Amber Engine Check warning staying on... Shocked
Looking through similar posts I can see it may possibly/probably be an EGR fault... Question
But as it's the first real problem for me it's off to Nene tomorrow for them to sort - (they are picking Mamba up, as they advised me not to drive it over to them)... Rolling Eyes
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #379132 15th Dec 2014 11:49am
i'd check earth connections, I had the same on a td5, intermittent but turned out to be battery -ve connector
do you know if the instrument binnacle has been removed for any reason ?
Post #379133 15th Dec 2014 12:04pm
Venomator
@bpman - Thanks, but no tampering as far as I am aware... Whistle  Rog... Mr. Green
The GREEN One...
Post #379134 15th Dec 2014 12:14pm
sorry, just to be clear, I did not think anyone was tampering with the binnacle, but there is a huge connector on the back with a snap-down lock on the back of the binnacle, if this was loose then you may get unusual happenings.
interestingly, the binnacle is also coded / paired to the 10AS unit
Post #379136 15th Dec 2014 12:18pm
Dave-H
Sounds more like an earthing fault yes .... hope it's not the earth for the ECU, a bad earth there often knacker the ECU! Sad Guns and Landrovers .... anything else is irrelevant.
Post #379137 15th Dec 2014 12:20pm
Venomator
Interestingly, the binnacle is also coded / paired to the 10AS unit
Sorry, my terminology bpman, not yours, I am not aware of what went on before I acquired Mamba. But, since coming to me in September, I have certainly not ventured anywhere near the instrument panel... Embarassed
It is probably a bit too scary for me to even think about, which is why I am hoping Nene will sort it relatively easily! Whistle
 Rog... Mr. Green
The GREEN One...
Post #379142 15th Dec 2014 12:35pm
Venomator
Thanks for the reply Dave... Thumbs Up
Would such things just sort of happen overnight though - all seemed fine over the weekend?
I do have an UltraGauge permanently fitted, through an OBD splitter, but that would not affect anything mentioned would it Question
 Rog... Mr. Green
The GREEN One...
Post #379143 15th Dec 2014 12:40pm
Dave-H
It's possible yes, Mine had TWO ECU's, both caused by poor earthing to ECU according to dealer, first one lasted 2 years, second one lasted 7 months Rolling Eyes
Doesn't mean that will be the problem with yours .... I'm just 'preparing' you just in case Wink Guns and Landrovers .... anything else is irrelevant.
Post #379145 15th Dec 2014 12:44pm
Venomator
Thanks again Dave, nothing like being prepared for the worst... Big Cry
I just hope it is sorted quickly - was supposed to be in London today and busy for the rest of the week needing wheels... Shocked
First major test for Nene anyway, will then decide whether to stick with them of use Marshalls again... Whistle
 Rog... Mr. Green
The GREEN One...
Post #379146 15th Dec 2014 12:51pm
Add a temporary Earth on top as the currentt one. (You can check it at the same time anyway)
Then see how it reacts.
Disconnect your trailer plug too if you have one, an Earth faukt there can cause all dash lights to light up!
Check the battery negative is tight.
Earth faults can do crazy things.
Post #379148 15th Dec 2014 12:53pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Had the same sort of issues on my Td5 DCPU, corrosion at the earth points, cleaned up fitted new earths and everything went back to normal Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #379151 15th Dec 2014 1:08pm
Venomator
Cheers Steve - battery negative is tight and clean, trailer plug is new from pick-up!
Just checked and it fired up and started perfectly with no sign of the Amber Engine Check light now... Shocked
This could be very irksome... Whistle
 Rog... Mr. Green
The GREEN One...
Post #379157 15th Dec 2014 1:26pm
mk1collector
That's odd! Mine (td5) for the first time this morning when I turned the ignition to let the glow plugs warm, the Rev counter went up to 50 for a second then went back down Confused After that it was fine and ran fine, but I've never had anything like that happen before.
Ray
Post #379163 15th Dec 2014 1:54pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
i had the same problem, i took out my start relays, and sprayed oil on all the conections, also pinching any terminals in the relay holder that felt loose, also I ran a new earth from under the seat direct to the battery. Never had the problem again.
Post #379165 15th Dec 2014 2:03pm
Venomator
@Will.I.AM - Are the start relays under the steering column with all the others over the top of the fuses Will? ... Whistle
Just been for a spin and a fill-up and everything is fine now... Big Cry
How bizarre, go figure... Rolling Eyes
 Rog... Mr. Green
The GREEN One...
Post #379193 15th Dec 2014 3:28pm
Page 1 of 3 123>
